They are the same. The gearratio difference on the 300z is in the rear end. Non-turbo rear .410. Turbo rear gear is a .386. 240 is .410.TogueDrifter wrote:Are the 300z gears taller than the SR gears?
That was the rear end numbers z1 gave me. Guess I should have checked with nissan directly instead of the biggest 300z aftermarket parts retailer east of the MISS. Where did you get the numbers from you quoted?daz1320 wrote:
z32 Turbo = Final Drive Ratio 3.692
Z32 trannies have gears that are physically wider (thicker) than SR/KA/CA trannies. A thicker gear increases your failure stress and thereby allows you to deliver more power to the wheels safely.Morph wrote:Alright guys whats the benefit from a 300 transmission. Sorry i know crap about gear ratios.
