300zx timing check issue
93Z
Car: 1993 300zx 2+2
I went to check on my timing today and I noticed that the arrow that point towards the degrees doesn't move. What's wrong?
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Are you talking about the crank pulley or the CAS?
93Z
Car: 1993 300zx 2+2
The crank pulley
t.mcginley.jr
1966 Ford Mustang
So you mean the slot on the crank pulley doesn't move when it's idling?
93Z
Car: 1993 300zx 2+2
Yes
t.mcginley.jr
1966 Ford Mustang
That shouldn't happen. The whole crankshaft pulley should rotate while the engine is running or none of the belts would turn. It's possible that the part with the notch in it has actually sheared from the rest of the pulley and is just sitting there while the rest of the pulley rotates. If that's the case, you need a new crankshaft pulley
