hotrodwannabe »
https://forums.nicoclub.com/hotrodwannabe-u231602.html
Mon Mar 17, 2014 8:20 pm
I recently acquired a 1990 z32 that was not running. After working on this for two weeks I had it running great, but I could not get it timed right. It appeared to be 180 degrees out, but I know this to be impossible. I finally found that the indexing pin on the cam for the CAS was broken off and the CAS was turned 180 out, I also found all of the wires on the secondary (E side) of the PTU to be criss crossed. I wired them up correctly and now the timing is correct! The guy I traded for the car told me that it needed a new motor. His loss my gain!
