300zx swap?? PLZ I NEED HELP ASAP
A home for 1983–1989 300ZX owners!
sonny300zx
Car: 300zx
wat can i swap in to my 86 300zx???, wat is all compatible.. plz help me!!
sonny300zx
Car: 300zx
.... come on.. where is everyone at.. i got 8 hours left???, well aniwaies.. the question is.. can i swap an 89-92 vg30de into my 86 300.???
nghtrain88
Car: 1991 Nissan 300ZXTT
you can pretty much swap anything in if you're willing to custom fabricate a little.. why do you have 8hours left?
sonny300zx
Car: 300zx
there is a vg30de on ebay.. for like 900 bucks.. and i need a new engine b/c mines locked up... so i can put a vg30de into my 86 300 correct???, wat else do i need with it??
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
harness, ecu, flywheels, clutch, guessing the oil pan and picup will require modding and the engine mounts should be at least close, and while I believe the bellhousing will bolt up I think the ring gear might be a different diameter so the starter becomes and issue, stick to the single cam, if you want power do the turbo swap but leave the twin cams otu unless you feel like going full custom
Return to “300ZX (Z31) Forum”
