marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Sat Sep 18, 2010 2:37 am
Since it isn't cranking, start with the basics. Pull off the little connector on the starter. Use a DVM set on DC volts. Put the red lead into the connector that runs TO the starter, and the black to ground. You may need to use some wire to extend the length so the meter can be read from above if you are doing this by yourself. Next, turn the key to start. The meter should read +12v. If it does, then your circuits from the ignition all the way to the starter are working. If not, step back through that circuit.
If it does read 12v, then you need to look at the wiring from the battery to the starter itself. It is one wire and a straight shot from the battery to the power connection on the starter. Look for corrosion or weakness in the wire. If that has 12v to ground, then check the ground connections from the motor to the battery. The main connection is on the top of the transmission where it meets the motor. It's possible that bolt isn't tight and you aren't getting a good ground.
If all of that checks out, then it may be as suggested above, a stuck starter solenoid.
