centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue Apr 11, 2017 3:17 pm
I think you want to get a compression test done on each cylinder. That will shed some light on your potential issues. A bit of a tune after sitting a year might be due. New gas in the tank (siphon out the old stuff), new plugs, charge up the battery, check idle and timing, drain, flush and fill all of your fluids, check belts, check hoses, etc. Do the gas, don't fill the tank more than half way, then do the compression test.
