Thanks Evildky, that helps to narrow it down a little. It's a n/a. 240 shifter should be easy enough. BTW what year 240?evildky wrote:what parts do you need? n/a or turbo? if it's n/a the shifter is interchangable with the 240sx, if it's a turbo it's interchangable wit a camaro or mustang I can't remember which off hand
Cool. Thanks.AZ-ZBum wrote:Any year. They're all the same.
Transmission doesn't have a nickname. 71C if you want.
You can usually find OBX short throw shifters for your transmission on ebay for about 25-30 dollars. That's where I got mine and it works wonderfully.240DrpTop wrote:
Cool. Thanks.
A real OBX is more than $30.240DrpTop wrote:Thanks Leegamer. I'll check that out.
I have a real OBX and it was 30 bucks. Never used B&M before.AZ-ZBum wrote:A real OBX is more than $30.
If you shift with a B&M and then with any other shifter, you'll understand why they are worth the money.
The B&M is the best short shifter on the market, bar none. Don't waste your time/money on any knock-off or any other short shifter.
Looks like it's super nice. If I planned on actually spending a little bit of money on a shifter, I would say it looks to be worth it.AZ-ZBum wrote:http://www.streetdynamics.com/...m.htm
