RedRum240 wrote:ok you dont know everything. I have seen a guy on ehre with a picture with 300zx seats ( leather) in his s13 hatchbak.. so dont tell me they wont fit.
I guess it's just how much time you are willing to spend with it.
I figure if you know how to use a welder, willing to reweld the 240sx brackets and the 300zx brackets together/apart or what not, then you should be able to find a solution.
I'm sure it will be one big pain in the *** tho. I just finished installing my aftermarket seats, which had sparco brackets "made to fit." Not only were they a ***** to install, but the seat went up too high (probably won't be a major issue if you put in the 300 seats), then i had to redrill the holes (not fun either) and test mount them w/o sliders, which is now a little more acceptable.
I'm not sure what the price of used 300zx seats is, but I'm sure it's pretty expensive. So, if you want to do it, go for it, I wish I had the ability to do it (I don't know how to weld jack, I can barely drill
My only warning is if you decide to go aftermarket seats, watch out for height problems if you are 5'10" or higher.
and watch out about tearing the threading - I almost did that, that would not have been fun especially since it was driver's side hole.
240DRFT: that like of rudee's is sweeet. The seats look tite in there.
