nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sat Jun 09, 2012 7:16 am
White smoke usually means head gasket. Either do a compression test or get the PH levels tested in the coolant. You can also see if there are bubbles in the coolant with the car running. I have never really liked that method cause it can be inconclusive. The PH testing is usually the quickest and easiest, cause it will tell you if your head gasket is leaking into the coolant.
The best test is compression test, this will tell you which cylinder it could be leaking from. It will also tell you the health of your engine.
