300ZX rotors identical dimension to q45 rotors?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
I've been taking a look at a complete 300zx brake system. I'm trying to save some cash by taking the least amount of parts from the car.
What I want to know, is if the front rotors are identical to q45 rotors. the reason being is because im currently running the q45 brake setup with a z32 master cylinder.
otherwise, does $340 seem like a good deal for everything? (all 4 brake calipers, rotors, rear knuckles, rear lower control arms, and e-brake)
thanks for the advice boys.
Rex
Car: None
Since some Q45 guys have "upgraded" to Z32 brakes, I'd say the rotors are not the same. I believe the Z32 are wider and bigger. Hunt down some posts in the Q45 sub-forum by Wes (elwesso) it should have all the details.
jdm_master_X
got it. the reason i asked in the first place was because i read somewhere they were at least the same diameter. i didnt take rotor thickness into account.
jdm_master_X
okay so i researched and according to importnut.com's z32 brake article, the q45 shares the same diameter of z brake rotos, but the thickness is 28mm, which is inbetween z thicknesses.
thanks!
