300zx revvvss itself?
sdkid123
Car: 1990 Nissan 300zx NA
hey guys so i changed the engine in my car and i got it to turn on but as soon as it turns on it rev's up to like 3500 rpm???I got soooo scared because the exhaust is off and its super loud soo i just shut it off lol :rotfl Anyways i set the tps to .45 and the cas is not set right but i want to get the rpms low before i set timmingt to 15 degrees so what can it be?
i heard the iav or something like that lowers your rpms or idle???
robomatic12
Car: 1990 300ZX TT
Make sure neither the throttle cable or the throttle linkage are binding. Set the cas to the middle of the adjustment range. I'm not sure if the iacv can make the idle that high, sounds like something is wrong.
sdkid123
robomatic12 wrote:Make sure neither the throttle cable or the throttle linkage are binding. Set the cas to the middle of the adjustment range. I'm not sure if the iacv can make the idle that high, sounds like something is wrong.
i disconnected the throttle cable to see if it was that and it wasent still reved up...what could be wrong? :facepalm:
es.biggs
Car: 1990 300ZX 5sp NA
Double check for vacuum leaks?
sdkid123
es.biggs wrote:Double check for vacuum leaks?
No I haven't because it to loud to hear and I don't want the engine revving up that high for too long:/
robomatic12
Car: 1990 300ZX TT
3500rpm isn't really going to hurt anything, it's a little hard on it if it's completely cold but you need to have it running to figure out if there are any vacuum leaks. or you could try using a boost leak detector
sdkid123
robomatic12 wrote:3500rpm isn't really going to hurt anything, it's a little hard on it if it's completely cold but you need to have it running to figure out if there are any vacuum leaks. or you could try using a boost leak detector
Ima put the exhaust back on so it won't be as loud and do that but also can maybe the iac be stuck open or something making the rpms rise? I can't think of anything else other than that... the car starts right up but as soon as it stars it revs its self?.. is it easy to swap the iac without taking the plenum off?
sdkid123
Fixed it it was the iav that was like half way open took the one of my old engine and it shot up to 2000 rpms but dropped right away to like 1200 now I just need to adjust it but timming comes first!!! :crazy: thanks for all your help I love NICoCLub :mike :bowrofl:
robomatic12
Car: 1990 300ZX TT
Nice, glad to hear you got it sorted!
