300ZX Rear Hub conversion Question
slayer6o6
Car: 1989 Blacktop 240SX SE
I have taken all four of the calipers off of a 90 300ZX and was doing the hub conversion and was wondering if I could just unbolt the hub/bearing assy. from the Z32 upright and just used the 300zx bearing and hub in my factory 1989 240sx upright. Will this fit, as it looks like it will? Any help is appreciated.
slayer6o6
For what its worth, I just want to get this done so that I have somewhat of a decent ride when I come to NOPI of Atlanta this year. Just thought that I would state that... Time is of the essence.
slayer6o6
Sorry, I should have specified this ealier; the upright that I am talking about is the REAR uprights. It looks as if the Z32 Wheel Bearings/hub assy. will bolt up to my 1989 240sx upright, and if so does this affect my wheel ofset in any way, good or bad, or any thing else, if this particular part swap is even possible.
crzycav86
Car: 93 Nissan 240SX KAT
the z32 hubs will bolt on to the s13 rear uprights.
It does not change the brake rotor position(you can use the original brakes w/ rotors drilled for 5 lug), so i know it doesn't change wheel position.
