sAyjAi wrote:so im tryin to put 300zx brakes for the rear. i put in the front already but the back seems really hard..where the drum set up is. the anchor doesnt seem to fit right. so the e brake shoes wont fit.
i bought everything that i need like..rotorspads e brake assemblyr33 e brake cable ss brake linescalipersmaster cylinder 1-1/16( doesnt seem to fit or dont know what year that would fit right)
if i need any more things plz let me know..i brought the car to my work place (wheel works) but they dont want to out washers to make the anchor stick out more..n my boss is being a b**** bout leaving my car there.
plz help this noob. im just tryin to get the car running again..(cant use old calipers run it till the pads fell out)
To run the complete 300zx rear brake set up on the s14 you will need these and need to do:
1. Z32 Rear ebrake assembly 2. Z32 N/A Rear hubs or S14 SE 5 lug hubs3. R33 or Z32 2+2 cables (With custom brackets)4. 5 Lug Z rotors
Step:
1. Remove your s14 hubs (19mm bolts)2. Remove the big 26mm alignment nut. on the back of the dust backing plate3. remove yoru s14 caliper/brake line/ebrake line set up4. It's a direct plug and play with the 300zx backing plate, hubs, calipers and lines.
But if you're still lost>>>>This will explain every question you have:
http://www.tunerclub.net/showt...-Swap!
