300zx Rear Brake Question
92gvr4#333
--can the rear disks be swaped on to the s14 and retain the parking brake? The ones I was looking at had an internal parking brake inside the rotor assembley. could the whole hub be swaped out or is there a better way?
Hijacker
Car: '92 240sx Convertible
'94 F-150
what you'll have to do is swap the whole hub carrier over to your spindle if you want to keep your stock spindle.
http://importnut.net/300zxbrakeswap.htm
Here's is the definitive brake swap. Should answer all your questions
