Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Sat Feb 21, 2015 7:56 pm
These don't have spark plug wires in the way that your buddy means. You can try doing a power balance test, in which you pull coil pack connectors one at a time to see where the problem is, if it sounds like a missing cylinder. I'd personally get it to a mechanic if you can't figure it out on your own and ECU comes up with nothing. I don't mean that in an offensive way, but not everyone knows how these cars work. They're a lot more difficult than most to troubleshoot, and without the right terminology and symptom description, we can't help very well. Could be a failed injector, bad coil pack, IACV, or any number of other things, and they all have similar, yet very different symptoms.
