bartZ32tt »
https://forums.nicoclub.com/bartz32tt-u128736.html
Fri May 29, 2009 7:22 am
I just purchased a 300zxtt on this forum two weeks ago. I checked all the fluids and set the boost low and took her for a little spin. Everything was fine until the next day when I took the z out on a longer trip. Not gonna lie, I gunned it a little but the boost was still set low and wasn't WOT. It cut off on me and ever since has ran differently.
However, I also noticed the oil pressure dropped. I was thinking it was just the oil pressure sender unit, because I let it sit a couple of days and started it up and the psi was back to normal. I then took her down the road and she drove just fine until I turned around to head back, which is when the psi dropped again. When this happens, I get rough idle and hard hesitation under acceleration. I took the front bumper off today so I could get it up on ramps to unclog the sender unit only to find this:
The previous owner told me, "I plumbed the recirc lines into one so it's running only one bov". Obviously by bov, he means a hole with duct tape around it. Needless to say I'm very upset and worried about any damage caused to my car.
Sorry for the long post, but I just want to be thorough and get a well-directed response as to what I should do. What damage might've been done and can I just slap a bov on the existing hole and be fine? Should I find stock recircs and put them in instead? To be honest, this is my first turbo-charged car and I dont know much about the forced induction side of it. All help is appreciated.
