nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sun Nov 20, 2011 12:14 pm
#1 on TDC is correct, the best idea is the 120k timing belt service. Might as well get this all done and a new belt is cheap insurance. This is one section not to go cheap on.
Yes and no about the marks. Those are just reference points. Look in the manual they have a step by step guide. After you get everything on and lined up the way its says, count the cogs on the timing belt, the marks will more than likely be off, this is normal. as long as they are close to the marks, the number of cogs are correct between each mark on the gears. Make sure the spark plugs are out, turn it by hand a few times completely, if there is any kind of resistance, stop, do not push through, its probably catching. Take your time, trust me. Ask any questions, we are all here to help.
