Old post... BUT does anyone have a pdf or link of that article? Thanksevildky wrote:jim wolf, stillen, and Nissan Motorsports all have upgrades for your N/A, of course adding some lightness doesn't hurt either, Sport Z Magazine did a very good article called "The Lady and the Tramp" they had an N/A Z32 running almost identicle times as a Z32TT
It's all out there for you, intake, exhaust, headers, upsized injectors, Cam's, remapped ECU's
Going to try the throttle body mod tomorrowSaint wrote:Start with a basic tune up.New nissan plugs wires,and fuel filter.Dyno it! To get a good baseline and make sure that there is no grimlanes.
Good, now for the free stuff:1- take the throttle pully cover off the motor( ya that plastic thing in the middle on top of the intake manafold)2- You will notice 2 throttle cabols.3- Moving the right pully all the way back to simulate wide op throttle, (WOT) Look over at the corresponding throttle body, notice that the throttle plate doesn't rotate to the back of the throttle? WTF? There's about 5% of rotation left! It's not realy at WOT!4- Go back to the pully you can either bend the plate back a bit or remove the screw that stops it. depending on what year you have.5- Do this to both pullys and bingo more power for free.
OK, Intake- serch the clasifides section for an INJEN system used.Full cat back exhaust. and high flow cats.Headers yes if you want to pay for the install.Engine grounding kitChip the ECU (swap a chiped ecu for your stock one)Dyno it! You should be arround 200 wheel hourse power.That's a good start.
You only have 3 options left.stay N/A , Twin turbo swap$$$$, Wet NOS (fuel and NOS injected into the air streem ahead of the throttle bodies).Have fun!
