datdude407 »
https://forums.nicoclub.com/datdude407-u165301.html
Sun Feb 26, 2012 5:19 pm
The difference between the NA transmission & the TT is the bellhousing. The NA bh has several tabs in it to compensate for the smaller flywheel. The TT has a bigger diameter flywheel, so it doesn't have the tabs inside. I brought a aluminum driveshaft for my car because I know that when I go tt, I will not have to replace the DS. like said above the NA rear end & the TT rear end is different. The NA has 4 bolts and the TT has 6 bolts.
