300zx n/a diff question
daz1320
Car: '93 vert
I am installing a 300zx rearend in my s13.I am wondering if I can use the 300 axles or do I need to get j30 axles or something?
Hijacker
Car: '92 240sx Convertible
'94 F-150
you'll need J30 axles. the Z axles aren't the right dimensions.
On the plus side, the J30 axles are thicker than 240 axles, so you'll get a stronger axle upgrade.
I managed to locate some CA axles on ebay with the stubbies, so I'm going the CA axle route, which uses the same bolt pattern as the 240. If i'm lucky, the shaft should be a bit thicker than the 240's axles
