300zx miss fire
nathanmoris
Car: 1992 300zx
My 300zx is not firing in cyclinders 3 and 5. I go around and disconnect each plug and only 3 and 5 dont change at all. How do i fix this or what out what exactly the problem is thanks jon
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
fisrt determine why 5 and 3 aren't running, it's either spark, or fuel or compression, I believe you can ohm the coil packa nd the injector to determine their condition, the compression will require a compression test, kinda of a pain on the Z32's
onelessissue
Car: 90 300zxtt
try swaping your coils around like take 2 and put it on 3 if the miss moves form 3 to 2 then its you coil pack
