300ZX master cylinder leaking... unknown hole
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
I got everything hooked up and when i started bleeding the system, brake fluid started leaking out of a small port located between teh front and rear fittings. its about 6 MM in diameter and i have to clue what it does. there is no visible thread or anything. i need to plug this thing up or something... car has been in the garage on stands for almost a week with stupid problems and now this. this is a remanufactured tokico master cylinder. any help or ideas would be very appreciated
NISTECH
it should be a threaded plug that goes in there.
got pic?
matt4pl
ok, i got a pic... its a matching Q45 master cylinder but the hole is the same
its the small on in the center
NISTECH
there is suppose to be a plug in that hole.
matt4pl
there was a little rubber one but it popped out im assuming. it was in when i started the install, not there anymore...
matt4pl
JB weld should work, right?
rewjr69
Car: 1990 300zx 2+2
Same problem here. Did the JB weld work??
