300zx master cylinder and other ?
Tictakman
I was reading the 300zx brake upgrade and was curious if anyone has done the following. has anyone just upgraded the 240 master cylinder to the 300zx master cylinder? was there any noticable difference. im planning on doing the front calipers and rotors, just dont have the money right now.
Also i was curious if anyone has thought of using the g35 brake calipers(brembo) and rotors? not sure if it was covered before or not. im guessing it would prob be too expensive when the 300zx brake upgrade is prob almost as good. or it wont bolt up.
Zak
A_Rivers
Car: 1998 Honda CRV, 1996 Yamaha FZR600
I am just about to do the swap to my car, I ordered the tociko unit wich uses a european style bubble flair for one of the front lines so I am looking for an adapter fitting. As soon as I find what I need and my SS brake lines and Motul 600F fluid come in I will be ready to tackle this job and get you some more info. ETA of upgrade 4-5 days.
Aaron...:uzi
Tictakman
hey man do u have a link to where the kit is? also there is brake line fittings sold at projectsilvia.com. not sure if thats the one but could be.
ZAk
A_Rivers
Tictakman wrote:hey man do u have a link to where the kit is? also there is brake line fittings sold at projectsilvia.com. not sure if thats the one but could be.
ZAk
Hey man,
Thanks for the tip, I was going to get one from Russells Brake Lines. I am not sure what "kit" your talking about. Explane and I'll be happy to get you all the info I can.
Aaron...:uzi
Tictakman
sorry i was talking about the tokico kit you referred to. i wanted to read about the european style bubble flair.
Zak
FrEaK
Car: Boosted D21 Pickup
It's a VW style bubble flair, if possible order the other manufactured unit that was made by NABCO which just plugged the hole with an allen style screw... the NABCO unit has the correct nissan style fitting..
A_Rivers
Freak is correct about the other master cylinder, I could not find the Nabco unit for a reasonable amount so I ordered the Tokico unit from NOPI for $87.00 everyone else wanted around $150 for the Nabco unit. So far I have had no luck finding an adapter after placing calls to Russells and Techna-Fit. Looks like I might have to make my own out of two diferrent units.
FrEaK
Just get a line made with the VW bubble fitting :)
Tictakman
**** guys im in the dark on this. is this a better alternative to the 300 master? gotta pic?
Zak
