300zx MAF w/ safc
Mike09
Yea I searched but could not find anything. I'm going to be installing an 300zx MAF into my mostly stock SR redtop but I was just wondering if I'll need a better fuel controller because I only have a Autometer A/F gauge and a first gen SAFC. Dial type. Will this setup work good??thanks
SpeedRacer1
Car: 1990 240SX, G35
Read the wiring manual for your SAFC, it will tell you how to run the 300ZX MAFS.
Mike09
Modified by Mike09 at 1:44 PM 2/19/2005
SpeedRacer1
The SAFC is a super AIR FLOW CONVERTER. Meaning it can alter the type of MAFS you use and change the signal it gives to the ECU.
Its what the SAFC and SAFC2 do well.
Mike09
The problem is when I went to Install it the manual say's to use the N-9 diagram but the pin's from the ecu are not correct. ECU#62. The pin's don't match up. there is no tach signal wire where it say's it should be and the recomended power wire I don't believe is the correct 1.
Also the manual doesn't give a setup/ or direction's on using the 300zx MAF with the s13 for the 1st gen SAFC. So when I installed the MAF it ran like crap and just stalled out????
http://www.apexi-usa.com/produ...1.pdfpage 9 gives the wiring daigram. page 22 gives direction's for non stock MAF's..
If any1 has the proper ECU diagram and can help me that'd be great!!!
SpeedRacer1
