300zx maf
916drifter
Car: 1990 240sx Fastback
Will the 300zx mafs work on a ka24e??? i think i need to replace mine. but if not, how do i clean the maf?
solaris22
you can use brake cleaner to clean the sensor
180fan
Car: 89 fastback
yes the z32 maf will work on the e. you'll need something to change the way the ecu looks at the voltage from the maf though, like a s-afc to make it work or an ecu reprogram. You might want to be careful with the cleaners as they're pretty high pressure and you might risk damaging it further if you give it a direct shot of brake/carb cleaner.
Dattebayo
translation=you must go to http://www.jimwolftechnology.com to get the upgrade
Jonny 290
what are you going on about?
Don't need to go to Jim Wolf. Get an SAFC or an E-manage. You'll be fine.
916drifter
where in the maf do i clean it? the little a55 hole inside of it? and does it matter what kind of brake cleaner? or just put the brake cleaner on the q-tip and stick it n the little hole.
