300zx lines
tex240
i just put on my z32 brake upgrade on the front and i used the stock lines with a washer as the spacer. What is the differece in the conversion lines the ones that i got that came with the car didnt work.
tex240
oh yeah i also have cracked lower control arms how bad is that. am going to see how much they are ifnot ican weld them. i have the polyurethane tension rod bushings could that have doent that? sorry forthe questions
trpower7
Cracked lower control arm is really bad. Do not weld it. No, the bushings couldn't have done that. Get SS conversion lines from http://www.pdm-racing.com or ProjectSilvia.com. They are the proper fitting. You first post is erroneous. The conversion lines are the proper sized fitting so that you done need an extra washer. If you but conversion lines for your S14 they will work. Stock lines CAN work with a washer but are not recommended. Stock Z32 lines will work as well.
tex240
thanks i am going to get the better lines soon
trpower7
Excellent. http://www.project-silvia.com has them for the best price
tex240
i ordered the ones from pdm this morning hopefully they will work better.
