300zx keyless entry
sdkid123
Car: 1990 Nissan 300zx NA
Hey just bought a alarm for my car but my car is a 1990 that does not come with the door actuator on the drivers side... can I simply take one of a 1995 or 1996 300zx actuator and mount it on my z?!? Thanks :gotme
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
May need some fabrication. Not sure. Your alarm system didn't come with actuators?
sdkid123
Ace2cool wrote:May need some fabrication. Not sure. Your alarm system didn't come with actuators?
I'm talking about the part that has to be put on the drivers door to be able to use the alarm remote to unlock it with out using the key... I saw a forum about it buy they used a aftermarket one I just wanted to know if anyone has used the stock actuator on the 300zx 1995 or 1996?
robomatic12
Car: 1990 300ZX TT
I'm sure an aftermarket actuator is cheapest option, unless you have a parts car or can get the oem one cheap. Either one will work the same
sdkid123
robomatic12 wrote:I'm sure an aftermarket actuator is cheapest option, unless you have a parts car or can get the oem one cheap. Either one will work the same
There's a junyard close to my hose that has z'sss ima check how much they are thanks for your help
Ace2cool
http://compare.ebay.com/like/1304231548 ... 602_304662
Just sayin. $6.
And the related items are even cheaper.
