es.biggs »
https://forums.nicoclub.com/es-biggs-u154499.html
Thu Apr 29, 2010 10:36 pm
Don't even try to retro-fit without properly evacuating the system of the R12. Mixing R12 and R134a will change the chemical make-up of the refrigerant and it will have an even lower boiling point than R12, which is lower than R134a. The R12/R134a mixture will work, and it will cool your air, but it is not how the system was designed to work. Boiling point plays a huge role in how the A/C system works, and lowering it will do more harm than good. You might want to consider taking it to a professional who is licensed to handle refrigerant...letting R12 into the atmosphere is terrible for the ozone and it is highly illegal. Without the A/C machine, I can't think of any other place to store old R12. But if you can figure it out you should sell it, as this stuff is worth as much as gold now!
The reason you would want to replace the receiver/dryer is because it has a "desiccant" inside it that absorbs moisture. A lot of times it is made out of silica, the same stuff you find in little packets in new shoes. Anyhow, the desiccant can get completely saturated in a little as ten minutes of being openly exposed to moisture in the air (anytime the A/C lines are removed and not plugged)
The desiccant then loses its absorption abilities and it will allow moisture into the compressor, which is bad news for any piston type of engine, which the A/C compressor is. Hydrolock is the word.
