300zx injector
nathanmoris
Car: 1992 300zx
I have 93 injectors with the clips..... i was wondering if the o ring and the injector cover that holds the injector in the rail is the same as the 90 injectors.. Do they match any other ones? thanks
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I beleive there are only a few kinds of injectors avaialable, the sidefeeds come in only one or 2 varieties, if it looke the same it will likely work assuming its the correct flow rate/ impeadance
onelessissue
Car: 90 300zxtt
there are 2 styles of injectors 90-93 and 94-96 the you can swap within those year brackets but make sure your flow rates are the same they are indcated on a colored dot on the plug on the injector in a 90-93 its normaly a black dot for the n/a and a green for the turbo 94-96 in a red for the turbo abd blue for the n/a
