300zx iacv acc cleaning
sdkid123
Car: 1990 Nissan 300zx NA
I took the iacv of my old plenum to clean I took the aac of to push the spring down to get all the gunk inside out anyways I put It back together and noticed that when I put the aac back the spring wouldn't push the black tube all the way in but when I take the acc out he spring does push it all the way in could it be that it's supposed to stay opened a bit or is the spring weak?!
GerryO
Car: 1993 J30t
Pearl White
Black Interior
http://home.swipnet.se/e-solutions/IdleTech.html
Imagine most of the moving parts are temperature driven and ECM controlled, plus they can probably be electrically tested.
grk nickafis
Car: Looking for something fun.
2011 GMC Sierra
Broken
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Yeah, you don't touch the internals of those parts. Spray with WD-40, soak shake and blow out with low pressure compressed air. Repeat.
grk nickafis
2011 GMC Sierra
I took it completely apart and had no problems getting it back together. Just take pictures with your cell phone of where everything goes and make sure you have the right tools.
Then again, the other way is easy like BigTDogg said
BigTDogg (MA)
grk nickafis wrote:I took it completely apart and had no problems getting it back together. Just take pictures with your cell phone of where everything goes and make sure you have the right tools.
True, you could do that, but I didn't want to chance it :)
sdkid123
heres some pics with the acc installed theres a little gap... and with it off it is completely closed ?
HERE IT IS WITH THE ACC OFF (NO GAP)
HERE IT IS WITH IT ON(A LITTLE GAP)
i ohmed checked both of them and there both good and it had lots of gunk in it.. which i cleaned
