300ZX hub assembly on S14
Ace
Car: S14
Quote »The twin-turbo Z rear upright is forged aluminum, which shaves 7 lbs of unsprung weight. Combined with the larger brakes, the whole unsprung assembly comes out only 2 lbs heavier than stock despite a massive increase in braking power and heat capacity. Note the different mounting point for the rear shock, however (lower left on each upright).[/quote]
Ok well I just got my rear 300ZX hub assembly and noticed that the aluminum hub assembly was basically the same as the stock steel one currently on my S14.
I don't know if it is right to call it a hub assembly, I am talking about the piece that connects all the suspension links. It is steel on 240s but aluminum on 300zx's. SCC said you can save 7 lbs on each side with the aluminum.
The difference is the shock mount. It is a bit different. My plan is to switch to coilovers this summer and I was wondering if I need to order 300ZX coilovers for the rear or what do I do. SCC said they ordered some custom setup or something. Is it the same for the S14 as the S13?
Thanks
Rob
jam149
The S13 and S14 upper shock mounting points are different - the s14 is much higher up, and so the shock body is much longer.
I don't know whether the 300Z's is close in height to the S13 or S14 - but I do know that with many of the coilover setups (like Zeal and JIC), that you can order a different bottom mount for the shock. That is, order a S14 shock, and a Z32 mount (the mounts on these coilovers are threaded on, so swapping is just unscrewing the old and screwing on the new).
joe
