Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Oct 01, 2008 9:52 am
First thing's first. Why isn't your walbro working? Has it been working for a while and just now crapped out? Are you sure this isn't a bad relay or bad fuse? Have you ruled ECU out?
On the 300ZX fuel pump, there should be an Orange wire and a white wire coming off of the 6 pin plug (chassis harness side, not the wires going through the sending unit cap)
If you don't have the chassis harness portion, the wires shoudl be in the 4 and 6 pin positions if the plug looks like
top123456
The white wire leads back to a control unit that varies the speed. Basically, the control unit is a variable resistor on the ground circuit for the pump.
