Toddles82 wrote:they all have 3 holes. Outside 2 are for the pad pins, and the middle one is for the pin spring.
THere is a picture that has a tap measure with different numbers measuring the rotor gap width.~30.2mm for the 26mm calipers ~35 mm for the 30mm calipers
So, measure the gap between the pistons?
Also, is there a write-up on a full 300zx brake swap on a '90 240sx? That's what I have and I would like to know what all I need? I have searched and can't find anything on the '89-'94 240sx swap. . .
