thrasherx89 »
https://forums.nicoclub.com/thrasherx89-u86000.html
Thu Sep 10, 2009 11:38 am
so this started as a post as a question but i discovered all the info courtesy of brembo.com, small writeup for some people, may help
for everybody considering a 300zx, q45, or j30 brake upgrade let me break down some info for you right here right now
z32 are 4 piston (better of the choices) come in 26mm (1990 N/A aluminum) and 30mm (1991 -1992.5 aluminum and 1993-1996 iron) thickness in rotors and both rock 280mm diameter and pertrude out 53.7m (30mm) and 57.2mm (26mm)
q45 (1990 - 1996) are 2 piston (better than stock) and come in 27.5mm thickness and 279.5 mm diameter and pertrude out 53.6mm
j30 are exactly the same!!
steps i took in finding this info is:
google.com
search: brembo.com 2008 catologue
north america --> usa
then go from there
all will fit on the s chasis and all require a 5 lug or drilling of a 4 lug into the rotor (performance change has yet to be varified by me, if anybody has info please post)
the minor difference of .5mm in diameter is really not a huge deal as far as i know (still better to use the right rotors!) and the q45/j30 rotors stick out 2mm more than the z32 (if you do the math: 53.7 - 30 = 23.7, 53.6 - 27.9 = 25.7, 25.7 - 23.7 = 2mm!) theoretically you could "shave off" half of the 2mm difference of the q45 rotors to keep it centered in the caliper, they should fit the z32 30mm fine (this will not work for the 26mm as q45/j30 are too thin)
idono if this is a alternative to finding z32 rotors as we all know q45/j30 are readily available in most junk yards
if anybody has any info on the topic please post thanks
Modified by thrasherx89 at 9:56 PM 9/10/2009
Modified by thrasherx89 at 9:59 PM 9/10/2009
Modified by thrasherx89 at 10:26 PM 9/10/2009
Modified by thrasherx89 at 10:50 PM 9/10/2009
Modified by thrasherx89 at 1:32 AM 9/11/2009
