300zx engine swap
palomaresrobert
Car: 300zx
I had just bought my 300zx and I been researching a bit but I was wondering is it possible to but a r34 twin turbo engine in a 300zx and would it be illegal in the state of CA and would it cost a lot?
nissanfreak12
Car: 92 300zx 2+2 TT
Yes, its is possible to fit a rb26 in there, been done before. Yes, you will fail emissions in CA.
If you have to ask if it ill cost a lot, you are no near ready to do this project. Yes, looking 10k+, ALOT of custom work.
palomaresrobert
Car: 300zx
nissanfreak12 wrote:Yes, its is possible to fit a rb26 in there, been done before. Yes, you will fail emissions in CA.
It will only fail the emission test would be the only problem in the state of Ca? And does it matter what rb26 engine they will all fit?
twinturbozxtacy
Car: 91 tt
you can make any engine fit, but its all going to cost a lot, heck the rb is 3K+ alone...
palomaresrobert
Car: 300zx
twinturbozxtacy wrote:you can make any engine fit, but its all going to cost a lot, heck the rb is 3K+ alone...
Alright thanks, but does that also mean I'm going to need a new computer chip? Sorry I'm a noob, just getting into cars lols
twinturbozxtacy
Car: 91 tt
chip? try a new computer along with a lot of other electronic plugs and etc...
if you have to ask these simple questions a swap is wayyyy beyond your abilities(no offense). unless you want to pay a shop to do it ALL for you.
Hackysac300zx
Car: 93 Nissan 300zx 2+2 N/A (TT motor in the works)
93 Nissan 240sx Vert (restoration in progress)
A shop here in Dallas quoted me 10K for a 25 swap including motor...soo add another 2-3k on that...
pearlbluezx
Car: nissan300zx
hi guys i have a question ,my 300zx had just snap the timing belt how much does it cost to fix it
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
pearlbluezx wrote:hi guys i have a question ,my 300zx had just snap the <a class="vglnk" title="Link added by VigLink" target="_blank" rel="nofollow" href="http://shop.ebay.com/i.html?_nkw=timing ... pan>timing </span><span>belt</span></a> how much does it cost to fix it
You should really make your own thread if you have a question, what you did is called threadjacking :nono:
But since its such a simple question, if your timing belt broke it will easily cost a few thousand to fix because at the very least you have bent valves. Unless you located a cheap used engine and did ALL the work yourself, then maybe only a few hundred or so.
