300zx engine problem
nathanmoris
Car: 1992 300zx
My zx is shutting down when i press down on the clutch and break at high speed... it wont idle, and needle will just drop donw to zero so then it dies.. but this only happenes when i go faster then 50 mph... i have to wait till the rpm needle reaches about 2000 then i pushed the clutch and then it will idle. does anyone know whats going on thanks
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
Check your ECU for codes: zerothread/249406
It almost sounds like either your TPS sensor is bad or your AIV is bad.
nathanmoris
Car: 1992 300zx
ok ill check those items out thanks
Canyoncarver
Car: '93 300zx
freakonaleash1187 wrote:Check your ECU for codes: zerothread/249406
Nice write-up Jared.
