masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Fri Mar 25, 2005 8:07 am
Ah, you mean the yolk! J/K.
Do you mean the final drive gear? Or the differential? I'm pretty sure they're swappable, but I don't know why you'd do that unless you were making rediculously high numbers on the ground. I know the NA 300ZX ran the same rear end as the 240sx, but the TT had a lower final drive ratio.
If you're just swapping internals, then I suppose you could pull the 240sx final drive gear and bolt it to the 300ZX differential. I know even the NA Z32 diffs were VLSD, so if that's what you're going for, then it makes sense.
