300zx ecu code
sdkid123
Car: 1990 Nissan 300zx NA
got home from ork and decided to drive around the block in my z i drove about two blocks and the steering wheel got really stiff thats when i noticed the car turned of turned it back on drove back about a block turned of again turned it back on and drove another block home.when i got home i turned it off and checked for codes even though the check engine light wasent on i got these
13*: engine coolant temp. sensor circuit
14*: vehicle speed sensor circuit
35*: exhaust gas temp. sensor circuit
i thunk i got code 13 because the wire to the coolant temp sensor doesnt have the clip to keep it in place.
I dont know were code 14-speed sensor is locared?
Is code 35 -exhaust gas temp sensor the sensor on the egr?thank you
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
The coolant temp sensor is most likely the culprit in this situation. The connector clip can be bought from Nissan. Either that, or you could get creative with a zip tie or two.
Not sure where the EGT probe is on the Z32, though on most cars it is on the exhaust manifold.
The VSS is on the trans, close to the Driveshaft output, IIRC.
sdkid123
thanks for the help i found a pic of were the vss is located i think i have a clip for the temp sensor laying around somewere know i just need to find a pic of were the EGT is located!")
Ace2cool
Hm, maybe someone else knows. I just spent about 20 minutes in the FSM EF/EC section, and the EGT isn't listed in there. Is it contained within the O2 sensor on these cars? Not entirely sure on this. Someone else have the answer?
sdkid123
Thanks for the help i cant find it eather:/
i drove my car today and it turned of on me twice again ,but i noticed that it only happens when im going over 40 so i thinking that the VSS is causing it to turn of?Thank you
Ace2cool
Do you have a cone intake, by chance? Also, when did it "turn off?" Braking, accelerating, clutch in, ect?
sdkid123
Ace2cool wrote:Do you have a cone intake, by chance? Also, when did it "turn off?" Braking, accelerating, clutch in, ect?
nope everythings stock i accelerated then let go of the pedal and coasted in neutral dont remmember if i had the clutch but thats when the car turned of and the steering wheel got stiff then i stopped and and it started right up? :frown:
i bought a used VSS sensor today ,iwill change it soon..
sdkid123
i think the coolant temp sensor is causing it to turn off ..i changed the VSS sensor today and it shut off again. this time i noticed the check engine light came on before it turned off..got home checked ecu codes and only got code 13.im going to get a new connector seeif that fixes the problem.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
It could be the sensor that's threaded into the driver's side EGR tube rear mounting flange.
http://www.z32photoguide.com/
The good news it that it comes out along with the EGR tube, and a VERY long soaking with/in penetrating oil might aid in getting things out and apart. I'd check the wiring and connectors first.
Suppose the code could also mean that exhaust gas temperatures are HIGH, which would probably result from the EGR valve opening, releasing exhaust gases into clogged EGR tubes. Carbon builds up inside their entire length and where they connect to the undersides of the plenum.
sdkid123
GerryO wrote:It could be the sensor that's threaded into the driver's side EGR tube rear mounting flange.
thanks for the help i havent got code 35 again only 13..hope i can fix the problem so i can start driving my z again!:)
Ace2cool
I'm 85% sure the coolant temp sensor is your problem. Get that fixed and report back.
sdkid123
Hey fellas
Drove the car the other day an it turned of again but this time it wont start!Changed the cas and ptu no luck car wont start but there is a gas smell in the exhaust so im guessing its getting fuel.i was gonna take the spark plug out to see if they were getting spark but couldnt find my long extension so i have to buy another one.im starting to think that the air regulator is stuck in the closed position not letting any air threw .what do you guys think?
sdkid123
Hey guys turned out to be the green ignition fuse in the fuse box next to the engine, my z starts right up now thanks for the help!:)
