Sorry but that was truly funny. The Drum setup is the parking brake. Unlike a 240 which applies the rear caliper, the 300z has a mini drum setup inside of the brake rotor.coupe240sxguy wrote:Why down grade from discs to drums... stupid and a waste of time if you ask meHere is an idea! Lets spend some money and downgrade to crap.
Actually I am doin this one for the second time so I can def. help ya out. Its pretty easy, first you need the parking brake assembly which is part of the backing plate. From there you either get the parking brake cables from a 300z 2+2 or you hack and mod your 240 cable and whatever cable comes attached to the used parking brake assembly you buy. To attach You simply remove the hub (at this point just install the 5 lugger and be done with it Check the sponsor thread for a great deal on Ichiba Hubs). The hub on the rear is attached by 4 bolts simply remove them and install the new backing plate.nissans13240sx wrote: I have been looking in the 300zx sticky and havent really come across a definate answer so... How exactly do i get my ebrake to work with the 300zx rear calipers? im guessing i need the drum setup??? how does it mount up though?
I do appologize, I later did discover what parts he was talking about and the setup. I first thought that he wanted to go from disc to no disc, but I now understand what he was talking abouteazye2000 wrote:
Ok, that was funny for a second....
Here's an idea! Learn about the parts before you talk crap... ...I'm not even going to explain
And as far as the backing plate goes, does it bolt up to the S13 rear spindle/knuckle without problems?
It depends on your situation. 5-lug, 4-lug and e-brake parts from which year z32 matters. This is one famous z32 brake swap and this article and nico link I posted will give you some idea on what to get and how to.
rofltastic!!!!!!!!!!!!!!coupe240sxguy wrote:Why down grade from discs to drums... stupid and a waste of time if you ask meHere is an idea! Lets spend some money and downgrade to crap.
As far as I know, z32 has drum e-brake setup cuz the car is heavy. Rear brake parts get heated up more, and when e-brake applies rear pads can make marks on rotors or worst case, get stuck. Pls correct me if I'm wrong.hybrid_flyer wrote:Unlike a 240 which applies the rear caliper, the 300z has a mini drum setup inside of the brake rotor.
