300zx Cruise light flashing HELP
romeoridgee
Car: 1993 Nissan 300zx 2+2 NA
93 300zx NA.
I just had my engine swapped for a working one bc a piston rod blew inside. before that i would press the on button for the cruise light, the cruise cont light comes on and i wouldnt be able to set it, nothing would happen when i press or pull on the lever.
after this swap, when I press the cruise on button the cruise cont light turns on and the cruise light flashes/blinks.
When I push up or down or pull on the set lever, the cruise light stops flashing, but doesnt set. also when i press the brake the cruise light stops flashing.
HOWEVER, when i press the clutch down, it continues to flash O.o :wtf2:
My guess is that the sensor that the clutch presses in when i fully release the clutch is damaged or broken, but when i look under neath, there are 2 buttons the clutch presses in.
Can someone confirm that its the button/sensor that the clutch presses in to cancel the cruise?
