nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sat Sep 14, 2013 4:53 pm
$3500 is actually a good deal if it includes paint and the new parts. That is pretty bad damage, it looks like the driver side where the fender attaches is pretty bent, that would also cause the sheet metal to crumble on the lower section. It can be a mess and a PITA to deal with.
If you are handy with a welder, and have a lot of patience and all the measurement, you can straighten it yourself. I had a similar issue and replaced the radiator support due to a hidden damage in the same area. It took me a good 20-30 hours to get it right, putting the bumper on, then off, etc.. Then the fenders, well you get the idea. Turned out actually pretty good and have zero issues. Mine was not as bad as yours though, it was just the headlight bucket.
Check out concept z performance, they have new stuff that you can get and replace. Or just go to a junk yard and find a front end that is in good shape and have them cut it off, make sure you cut it further back than where you cut it on your car.
