300zx Crank angle sensor problem?
leono
where is the setting mark on the crank angle sensor. I did the timing already?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I don't quite understand your question? the CAS mounts in the front of the intake cam on the drivers side, it's got several hash marks to allow for adjustment, if you pulled your timing belt and are trying to gert it back in the right place you should have marked it before removing the cas, all is not lost, you can hook up a timing light to the leads to the coil pack on #1 and set your timing by adjusting the CAS
