Beems240sx »
https://forums.nicoclub.com/beems240sx-u97311.html
Mon Mar 15, 2010 4:15 pm
i have 30mm 300zx front calipers for my S14. everything is new (pins, springs, pads, shims). it is soooo close to fitting but i just cant get them on. the pistons are compressed all the way and there is no fluid in the calipers at all. when i removed the heat shim, (black vented shim not the silver one), they will go on with a rubber mallet. the only idea that i have is to stick a vacuum pump to the brake line to suction the pistons in just a tad more. any thoughts?
