300zx calipers
locoluna825
Car: 90 240sx coupe
I was at pick a part today and found a 300zx sitting in there.the whole car was still there. front smashed in need a whole new front clip but that mean the car was running So i noticed the calipers were still there and looked pretty good... anyways i wanna get them for my 1991 240sx. My question is
Is is it worth buying them? there 26 dollars a caliper.What else do i need of the car to do the swap?Can i use the 5 lug hub off of it too? How about the brake lines what do i use?
thanks let me know
Modified by locoluna825 at 1:36 PM 5/3/2009
mazersx
Car: 240sx !!
Go grab it..You can't use the front but you can use the rear hub.You can get the rotors if it look good and redrill it to 4 lug and use it.. If you are planning on using it make sure to get all the bolts for the caliper and the bracket and the brake lines.everything else is pretty much plug and play.
locoluna825
Car: 90 240sx coupe
cool ima get it
i2ice4m3
Car: COUNTERSTRIKE!
go for em!! probably a good idea to rebuild before use, though.
