Nealoc187 »
https://forums.nicoclub.com/nealoc187-u17062.html
Wed Nov 03, 2010 6:00 pm
I realize I am responding to posts that are like 3 years old but I feel the need to correct some bad info given in this thread. Everything I am about to type refers to FRONT BRAKES ONLY.
J30 front brakes are smaller than 300zx front brakes are. The notion that "the J30 front brakes are made to stop a larger car than the 300zx" is ridiculous. The cars weigh almost the same, and the 300ZX brake rotors are physically larger. The 300ZX caliper is also physically larger than the J30 caliper is, as it is made to accommodate that thicker front rotor and also must house 2 more pistons than does the J30 caliper.
J30 front rotors are 28mm thick x 11" diameter
300ZX front rotors are 30mm thick and 11" diameter (except for the rare 26mm thick x 11" diameter rotor used on the first year or two of the normally aspirated 300zx).
If someone is to do J30 to 300ZX brake caliper swap they will need to get custom brake lines - which are readily available. 300ZX calipers and J30 brake calipers use a different brake line fitting and fastener style.
With regard to Q45 brakes, the 90-96 brake rotors are identical to J30 brake rotors. The Q45 front caliper is virtually identical to a J30 caliper. It is not THE SAME, but the two calipers are so similar as to be close to indistinguishable. One is not an upgrade over the other. The pistons are the same size, the pads are the same size. I have used both brake calipers in various brake swaps on other cars. 97+ Q45s have a larger diameter but same thickness rotor, and larger caliper with larger pistons and larger pads. The newer still Q45s use a similar caliper with a tiny bit larger piston, but actually uses a smaller pad and smaller rotor than the 2nd gen Q45 does.
I've done a heck of a lot of Nissan brake upgrades and even more research on possible future upgrades, I've run like 7 different combinations of rotor and caliper on my car, and I've mocked up a few others, and taken dimensions of a number of others. I'm up to my eyeballs in brake specs for different Nissan/Infiniti cars. Chump if you need some ideas for "OEM looking" brake upgrades for your race car, feel free to hit me up. Nissan has a lot of options and there are some REALLY big rotors you can get on there, or some more modest options which are still an upgrade to the 28mm x 11" J30 front brakes that are neither a lot of work nor a lot of money.
