300ZX Brake Upgrade ?
vutony
If I do a 300ZX brake upgrade on a '92 240SX will I need to convert my 4 lug to 5 and wat size calipers do I need 26mm??? or 30mm??? (SR motor)
SmithSR
Car: 240sx
Please use the search function. I'm normally not quick to throw that out there, but using the search "300zx brakes" in the Tire/Wheel forum delivered 27 threads. Search then read. All the info is well documented and worth the time it takes to search and read. I did
vutony
I did do my homework, it was like 50/50, some says 26mm and other says 30mm so Im lost.
llamabeta
Well if homework was done, you should have discovered:
30mm or 26mm is your choice it does not matter.
If you are attempting to fit them with stock wheels on an S13, I refer you to this:
http://www.sillbeer.com/s13sewheels.php
From my knowledge on S14's I think the 26mm should just clear.
30mm you will need new wheels or spacers.
You do not need to have 5 bolt hubs. You can just get the 300ZX rotors redrilled to utilize the 4 lug pattern.
Don't forget the conversion lines needed as well.
A very good resource for this is:
http://importnut.net/300zxbrakeswap.htm
I hope this helps.
