300zx brake upgrade
1991ls13
Car: s13 ls1 hatch
i was wondering if your able to use the s13 bolts to bolt the 300`s to your car?i dont see anything about this on the swaps i`ve seen.
94_240sx
Car: 94_240SX
Good point. You know what? I think they'll work. I know it because my z32 calipers didn't come with the bolts, so I must have reused ones from my s13.
gumby74
They will work.
The only differenc I noticed was the Z bolts were just a hair longer. Maybe the amount of space of an extra thread.
1991ls13
Car: s13 ls1 hatch
well pretty much have everything to get it started and well, i cant fit it on the rotor. i know its a 30mm cause i measured and im pretty sure its just the pistins are to far pushed out, anyone have any tips on how to get them to go on?
gumby74
When swapping pads without removing the caliper I picked up a cheap C clamp, and had an old brake pad welded onto the end. I simply remove the worn out pads, install my modified C clamp and proceed to tighten the screw. Doing the inside pad is a bit more annoying, but still rather easy.
If the caliper will still not go over the rotor, you may (obviously) have the wrong size caliper.
1991ls13
Car: s13 ls1 hatch
lol
duh, thanks idk why i didnt think of doing that
thanks alot again
VanIsleS14
Car: '97.5 S14 Kouki & good list of mods, '03 X-terra w/6" lift & 33" MTRs, '87 Samurai w/5" lift & 31"
gumby74 wrote:They will work.
Hope you got the aluminum calipers and not the iron ones.
