Skull-leader »
https://forums.nicoclub.com/skull-leader-u15056.html
Mon Apr 05, 2004 6:18 am
heavy throttles prices arnt that bad. Considering they dont fool around with cores. they give you calipers, front and rear pads, front and rear brake lines, and front and rear rotors for somewhere around 800-900 dollars. If i can recall the brembo kit costs an upwards of 2500 and the rotara kit costs 3000 and the endless 6 piston kit and alcon kit costs over 4g's. I coulndt bare to lie to autozone, and if i built up the courage, i'd get the one nissan fanatic in there.
the cheapest way is to just goto a junk yard and get the calipers off of a z. I did my brake upgrade, I got some used calipers and kept the stock rears, did kvr brake pads all around, earls steel braided all around, kvr rotors in back ,and brembos in front. i forget how much i paid, but it was around 900 or so. also dont forget, you'll need a z32 mastercylinder, unless mad pedal drop and white-knuckle braking experiences are your thing. If your boosting, you need to add a one way valve between the brake booster and intake manifold too.
