300zx Brake Swap
TwoFortyCoupe
Car: 1991 240sx w/S14 KA-T
T3/T4 .63 AR 50 Trim
Audi R8 Ibis White Paint
2007 Acura Tsx
Quick question,
If I pulled Calipers from a N/A 300zx can TT rotors fit? At Autozone, the replacement calipers for N/A and TT are the same, so I'm assuming that 30mm rotors will fit N/A calipers.
Any input is valued,
Thanks,
TwoFortyCoupe
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Yes,.its all compatable except the early 300zx n/a which is 26mm. I think the only difference is the tt is lighter aluminum calipers.
TwoFortyCoupe
2007 Acura Tsx
How can I tell if its an early 300zx caliper or a later one (any markings etc.)
compactfean
daily
I've never seen the 26mm so im not sure. Obviously a 30mm thick rotor with pads (new) won't fit in a 26mm caliper. That's the only way I can think of.
biggie
compactfean
daily
So i just read that and no, there are no markings too indicate a 26mm setup.
biggie
The "26mm Aluminum" calipers were used ONLY on 1990 non-turbos. They used a 280mm x 26mm rotor.
Use a magnet to determine alum or iron. If iron they are 30mm. If alum measure to see which they are:
biggie
But if he pulled the calipers from anything other than a '90 Z32, then they are 30mm. And N/A and TT rotors are the same, except for the '90 model.
TwoFortyCoupe
2007 Acura Tsx
I measured my rotor and that is 1.05inches which is about 26mm
biggie
Believe the rotor will be smaller than the caliper though. You would want to measure the caliper to be sure which you have.
