240sxOwner wrote:I have looked at the caliper and it looks almost like the brake pads are touching closer to the hub than they were before. You can tell where the pads have been grabbing since install, and now you see another 1/4" of area that looks like is now touching....
My 300zx brakes have never really impressed me as far as performance. They do not feel as though they grab as hard. They lock up quite easy on hard braking. My best 60-0 is 149 ft!!! I hope maybe i just have some cheap pads. Mine are aluminum 30mm, with crossdilled & slotted front rotors. The rear are still stock 240 brakes, as well as stock master cylinder.
Did the wheel or assembly get hit? It is possible that the assembly is bent. Also make sure the line has not collapsed and isn't kinked. If all that checks out, then more than likely the caliper is stuck and will need to be rebuilt or replaced.
As far as performance. Of course they are going to feel funny. The proportioning is going to be funky because you went to large volume fronts, but left on the low volume rears.
As far as them locking up. If the rears are locking you have a proportioning problem. If the fronts are locking, then you really need to get some better tires. The brakes can only do as much as the tires will hold.
